Re: [HSS] brake adjustment help needed
Hudson Town Sedan wrote:
Lew, the adjustment procedure must be followed in the correct sequence,>
> Some weeks ago I had the brake shoes relined on my '29 Town Sedan. The
> new linings are thicker, and even with the adjustment wheel set to
> minimum spacing on the shoes, I am getting dragging on two of the four
> wheels.
> I understand that there is a way to cure this by adjusting the
> eccentric adjustment bolt on the brakes. The problem is, I don't know
> where it is, and I can't figure it out based on some Bendix brake
> literature that I have obtained. Can anyone provide specific guidance
> for me here?
> Lew Phelps
> Pasadena, CA
> 1929 Hudson Town Sedan
> http://home.earthlink.net/~hudsontownsedan
otherwise you up the creek without a paddle! first, loosen off both
large anchor pin nuts, free of the backing plate, so the anchor pin
anchor can slide up and down. Then loosen off the eccentric lock nut
and turn the eccentric to it's inward position. The eccentric is at
the rear of the backing plate, on the flat inner surface. Next turn
the notched adjuster between the shoes so that the brake shoes are as
absolutely tight as they can go, then tap the ends of the anchor pins
with a lead hammer so they assume their natural position, and tighten
the large nuts. Then back off the notched wheel so the wheel can
turn. Then turn the eccentric so the rear shoe is just contacting the
drum. Now tighten the notched wheel again until the front shoe is just
contacting the drum, and you should be just about there. You may have
to go over this procedure a few times just to get things right. Good
luck,
Geoff.
