new owner needs more help - thanks
Thanks for the ideas on straightening out the mixed up rods and
bearing caps, and on shimming procedure, etc. As I mentioned I saw
numbers stamped all over the rods and caps, and nothing seemed to
correspond except the number 6 rod and cap. I took detailed notes of
the rod and cap markings visible from crawling under the right side
of the car, then from the left side, then rotated the crank a quarter
turn and repeated. I was able to conclude that 3 caps had been put
on 180 degrees different than the rod. Since the dippers pointed
correctly, I'll need to move them from an odd cylinder to even one
(or visa versa) so I can spin the cap around and still have it dip
correctly. The remaining 2 rods had each other's caps. In the end,
I believe I do have a set stamped 1-6 on rod and cap, although many
of them also have several other sets of numbers on them as well.
I now have zero confidence that the engine was put together
correctly. It appears the pistons could go in two different ways
(with a 180 degree rotation). Can anyone confirm for me which way is
correct - should the slot that is cut out of the wall of the piston
face the manifold side of the engine, or away from the manifold
side? I'm guessing it is important for proper oiling, particularly
since the slot in the piston ends at the oil ring. The way they came
in the car was with the slot facing the non-manifold side.
Thanks for the help.
Curt Fullom
Curt Fullom
