Re: [HSS] Digest Number 728
Would you be able to resend HSS Digest Number 727.
> Community email addresses:
> Shortcut URL to this page:
> There are 8 messages in this issue.
> Topics in this digest:
> 1. mismarked Super Six hubcap on ebay
> From: Hudson Town Sedan <hudsontownsedan@earthlink.net>
> 2. Re: mismarked Super Six hubcap on ebay
> From: "Kit Foster" <foster@netbox.com>
> 3. Re: mismarked Super Six hubcap on ebay
> From: Hudson29@aol.com
> 4. Re: mismarked Super Six hubcap on ebay
> From: Geoff Clark <geoffclark@xtra.co.nz>
> 5. Re: new owner needs help with 1929 Hudson
> From: "John Meadows" <meadows@dcsi.net.au>
> 6. Re: mismarked Super Six hubcap on ebay
> From: "hudson2x28" <hudson2x28@yahoo.com>
> 7. Re: mismarked Super Six hubcap on ebay
> 8. Re: mismarked Super Six hubcap on ebay
> From: Lew Phelps <hudsontownsedan@earthlink.net>
> ________________________________________________________________________
> Message: 1
> Date: Mon, 19 Aug 2002 05:23:17 -0700
> Subject: mismarked Super Six hubcap on ebay
> Item # 1852390681 is described as a '29 Hudson hubcap. It ain't.
> Anyone know for sure what years it would apply to?
> It's also NOS, so when the proper year surfaces, it would be a nice item
> for someone.
> Lew Phelps
> Pasadena, CA
> 1929 Hudson Town Sedan
> http://home.earthlink.net/~hudsontownsedan
> [This message contained attachments]
> Message: 2
> Date: Mon, 19 Aug 2002 11:35:00 -0400
> Subject: Re: mismarked Super Six hubcap on ebay
> > item for someone.
> The factory photos in the Butler and Conde books show this style for
> 1919-28 (wooden artillery wheels, of course), although it's not clear if
> there are any size/thread variations over the years. They come in two
> styles, the "Hudson Motor Car Co." as shown, and one that reads
> simply "Hudson Super Six." My 1925 Brougham has the latter. The
> December 1926 Parts List shows only "Hub cap," p/n BZ 16270
> (front), BZ 15187 (rear) without illustration (85 cents at that time). The
> fronts (which the eBay cap is) are larger.
> In my experience these are not exactly rare, though I don't think I've
> come across NOS very often. I stopped collecting them about 20
> years ago when I had accumulated enough to replace my poorer ones.
> Kit
> Message: 3
> Date: Mon, 19 Aug 2002 12:04:05 EDT
> It is very hard to tell what year it should go on. It will fit the front
> hub of a '28 and earlier Super Six. We had a thread about this some time ago
> and I think we discerned no less than 4 variations. I know I have two
> variants on the '26 Coupe! Too bad nobody knows what years the different caps
> should go on!
> Fullerton, California USA
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.HudsonSuperSix16-29@yahoogroups.com
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1939 Cadillac Coupe (How'd that get in there?)
> Message: 4
> Date: Tue, 20 Aug 2002 08:29:19 +1200
> > item for someone.
> > Lew Phelps
> > Pasadena, CA
> It is 1928 and earlier, all models back to around 1919. before that I
> believe they were brass,
> Geoff.
> Message: 5
> Date: Tue, 20 Aug 2002 08:12:12 +1000
> Subject: Re: new owner needs help with 1929 Hudson
> Hi, good to see you made the right choice of cars at the auction.
> In respect to the rods and caps being assembled incorrectly, these would
> have been machined to size with the shims in place. You must determine the
> correct caps to suit the right rods.
> 1. Check crank big end diameter with micrometer for size and roundness.
> 2. Make sure all big ends are the same size.
> 3. Get someone to machine a piece of steel to the same Diam. as the crank.
> This must be the same size and if possible be ground on a cylindrical
> grinder.
> Make it about 4" long so you can place it in a vyce and assemble each rod
> and
> cap with shims etc. This will assist you in sorting out the caps and rods.
> When correctly bolted together with shims etc. at 40 -45 ft lb. the rod
> should just drop under its own weight. You may have to scrape the bearing
> using bearing blue to get the the right fit etc.
> 4. Restamp the the rods and caps.
> Hope this helps
> John.
> ----- Original Message -----
> From: checknyt <cfullom@home.com>
> To: <HudsonSuperSix16-29@yahoogroups.com>
> Sent: Sunday, August 18, 2002 1:36 AM
> Subject: [HSS] new owner needs help with 1929 Hudson
> > I am the person who purchased the 1929 Standard Sedan that was
> > auctioned last Saturday near York, PA.
> > I have a couple of British cars which I have rebuilt, but I am new to
> > Hudsons. They were also auctioning an XK120, but when I checked out
> > the 1929 Hudson and researched it, I ended up buying it (instead). I
> > would classify it as an older restoration, I believe in the late
> > 1970's or early 1980's
> > After the auction I met someone who said they had heard the car run
> > beautifully last year, and had ridden in it. It had a new clutch in
> > June, 2001, and was driven around 650 miles since then. The former
> > owner, Bill Small, died late last year, and was in the process of
> > working on the engine at that time. It was sold with the
> > understanding that he had done somewhat of a rebuild because he was
> > not satisfied with the performance and upon restart after reassembly
> > there was a knock or noise that was never fixed. I spoke to several
> > people that had known him, and supposedly he was very good
> > mechanically, but was sick at the time he was working on it.
> > Supposedly he only ran it a few seconds and shut it off, but died
> > before he had a chance to repair it.
> > Before the auction, an out-of-town person familiar with Hudsons was
> > hired to see if he could fix the engine. He removed the pan and
> > examined things, and said he believed two rods were in wrong and that
> > the head would have to come off, and he therefore could not fix it in
> > one afternoon. He subsequently bid on the car at the auction, for
> > what that's worth.
> > I found one of the intake valve clearances to be very large, caused
> > by a stray washer laying between the head and the rocker assembly.
> > After fixing that, I started the car, believing I had fixed the
> > problem. Of course it wasn't that simple, and it does have what I
> > believe is a rod bearing knock.
> > A have pull down the oil pan, and trying to figure out what to do
> > next. All the rods have the proper right-hand or left-hand offset as
> > required. None of the rods seem to have play in the bearing, but
> > checking for play in the 3 or 9 o'clock position is hard to do
> > because it requires enough force to move the piston up or down.
> > >From a "Parts Lists", I noticed the rods alternate with respect to
> > the slight of offset they have coming off the crankshaft. They have
> > two distinct part numbers, requiring 3 of each rods for the engine.
> > I have a spare rod, and it appears that you could just flip it 180
> > degrees depending on which cylinder you are on to get the proper
> > offset, then of course the cap and dipper would have to go in the
> > direction of proper "scooping". I am guessing this would not work
> > though, because you might now have the cap flipped 180 degrees from
> > the machining that was done on the bearing.
> > Inspecting my engine, all the rods seem to have part number 30560 on
> > them, followed by an "L" with a circle around it. I'm wondering if
> > half of them should have an "R", or if the "L" means something other
> > than left-hand, or perhaps since the bearing have no-doubt been
> > redone at some point it may not matter?
> > Another unusual thing is that the rods and caps have lots of
> > different numbers stamped on them at various places, typically where
> > the bolt hole is cast, which I think was to designate the cylinder
> > number. Other than cylinder 6, which has a 6 on both parts, the
> > numbers on the caps don't match the rods, but it's not as simple as
> > seeing the 4 cap is on the 3 rod, or anything like that. For
> > example, one rod has a 5 and a 7 (why higher than 6?), and the cap
> > has a 2. But no rods have a 2, and no caps have the 5 and7 on them.
> > Perhaps it doesn't matter if the bearings have been redone, but I
> > don't seem to have a set of 1-6, rods and caps, as I would have
> > preferred.
> > Can anyone please give me the background information I'm obviously
> > missing, and ideally some advice on what to do next. I'm wondering
> > how the mechanic that checked it was able to conclude two rods were
> > wrong, or if that was a guess. How would I determine which two?
> > Also, what's the best procedure to follow for getting the shimming
> > correct when I do reassemble it?
> > Could it be a simple over-shim problem that I can check for and
> > correct without removing the head? I had thought that was more
> > likely than a situation of an experienced mechanic getting the rods
> > interchanged, but it conflicts with the opinion of the guy who
> > checked it out, so I don't know.
> > Thanks much to anyone who can help. I've never driven a Hudson, but
> > look forward to it, the sooner the better.
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Message: 6
> Date: Tue, 20 Aug 2002 08:45:16 -0000
> Yes, it's the same as those on my '28 - and I therefore would bid for
> it myself except the seller will only ship in the USA - silly really
> marketing it across the world but only being prepared to ship within
> your country - So good luck USA bidders - you'll have no overseas
> competition
> Brett
> nice
> > > item for someone.
> > > Lew Phelps
> > > Pasadena, CA
> that I
> > Geoff.
> Message: 7
> Date: Tue, 20 Aug 2002 08:45:40 -0000
> competition
> Brett
> nice
> > > item for someone.
> > > Lew Phelps
> > > Pasadena, CA
> that I
> > Geoff.
> Message: 8
> Date: Tue, 20 Aug 2002 04:19:55 -0700
> I tried to reply to this offline, but the email bounced with the
> following error message:
> Sorry your message to hudson2x28@yahoo.com cannot be delivered. This
> account has been disabled or discontinued [#102]. - mta594.mail.yahoo.com
> Anyway, if you want the hubcap, i will bid in your behalf and then
> re-mail it to you.
> this will cost you a little extra -- the additional postage from seller
> to me -- but otherwise it'll be a straight passthrough of costs. You
> can pay me via paypal when it's all done.
> Lewis M. Phelps
> Pasadena, CA
> > competition
> > Brett
