engine back together, but need clutch help
Thanks to the feedback and advice received here, I was successful in
sorting out the engine problems on the 1929 Standard Sedan I bought
at auction last month. It seems to be running nicely, and now that
it is registered and insured (Hagerty worked out great for that!) I
was finally able to take it for a spin.
Unfortunately, I ground the gears on every shift, including going
into low or reverse with the car at idle. According to a sticker on
the door jam, the clutch was replaced in June 2001 about 600 miles
ago. The car sat undriven for at least Feb-Aug 2002, possibly since
fall, 2001.
I checked for a stuck clutch by putting it in gear and cranking the
starter, and the car wanted to move forward. I searched the existing
messages and got advice about towing it (in gear, clutch pedal down),
which seemed to immediately free it. Now, with the engine running, I
can have it in gear with the clutch pedal down, and the car stays at
rest. Still can't shift without grinding.
I drained the fluid and replaced it with 1 and 1/2 cups of
oil/kerosene mix. Still no improvement.
I think I correctly checked the measurement of "free movement" that
is mentioned in the handbook/manual, which I interpret to be done
under the floor board - it is approximately 3/4" from the bottom of
the board to the pedal arm when it is not depressed. I am confused
if that's the correct way to measure it or not.
The pedal does go clear to the floor board when you push down, so I'm
thinking I may need to lengthen the linkage. I am also wondering if
the throw-out bearing could be worn out, but I'd like to think the
prior owner (now deceased) would have replaced it if need be when he
replaced the clutch. I'm also thinking that maybe the surface of the
flywheel is not clean, or the new oil not yet where it needs to be,
and driving it a while (intentionally slipping the clutch some?)
might cure things.
Can anyone offer some suggestions on what to try? Thanks.
fall, 2001.
might cure things.
