The 29 Starts Too!
A few days after the '26 ran, it was time to try the '29. With it's bad
clutch and tricky motor, the '29 has been getting very little use. I think it
was out only a couple of times all of last year, and also like the '26, it
had not turned a wheel this year at all.
The '29 has an Optima 6v battery that is even older that the one in the
'26 and sadly, the charging system is inop, so the electrical system is total
loss. This means that the chances of getting the car running after so long
seemed slim.
This Hudson still has it's electric fuel pump. The parts have been
collected to convert it back, but the work still needs to be done. Firing the
'29 is usually pretty easy. Retard the spark, advance the throttle, pull out
the choke, turn the ignition "on" and wait for the fuel tank to quit ticking.
An easy prod of the starter pedal turned the motor over hopefully, and
amazingly, this Hudson also fired, just like it's former stable mate, the
'26. Once again, I was not prepared for such quick success, and had to move
rapidly to readjust the controls to a less frantic level.
After filling the radiator and letting the motor warm, it was time to
test the clutch. As expected, it was well stuck and the whole car rocked
backwards trying to free the clutch by starting it in gear with the pedal
depressed. It did free off and was as good as it ever is after that. This
clutch is not good, and driving the car in town is no pleasure, but it should
be fine for open road touring like the AllCal Tour is going to be.
Well, two running Super Sixes, which ought to go! Stay tuned!
seemed slim.
