Re: [HSS] 1929 Timing Chain
jjpippers wrote:
Yes, there is a timing chain adjustment, outlined in the owner's manual.>
> I am rebuilding the engine in my 1929 Hudson Super 6. While the
> engine is in very good shape overall, the timing chain appears to be
> quite stretched. Is there an adjustment procedure, or should I
> replace the chain, are new chains even available? (I would like to do
> this engine right and never get this greasy again!)
> Paul H
Remove the three cap bolts from the flange, and turn the notched
adjuster towards you from the top, this will bring the eccentric
sprocket around. Whatever you do, don not hammer on these notches, as
they are cast iron and will break off. Get back to us if you have nay
difficulty, and I'll send you a photocopy of the procedure.
Geoff.
