Re: [HSS] Essex Misc parts needed
Chuck wrote:
How many do you need? I can probably find a few here, but you could>
> As the Essex is finally coming together I find there are some parts I
> need.
> 1- Wheel mounting bolt for wooden wheels (looks like a Carrage bolt
> with a bent lip on 1 side.
probablyfind some closer to home, or else make them out of carriage
bolts.
>These are just a U-shaped channel, easy enough to manufacture. They
> 2- Headlight cross bar The bar that hold license plate and goes
> between the two lamps (painted or chrome?)
were painted.
>I made these up for the coupe I restored recently. You can either
> 3- Left door striker plate and allignment parts that mounts to body.
> 4- Bolts that hold pivot point on Rumble seat.
machine a large bolt down to a collar and thread, or put a sleeve on a
smaller bolt.
>K-Gap have these in stock, or can be got from other rh\ubber suppliers
> 5- Rubber gaskets for base of windshield to cowl.
as well.
> ThanksI can't help you with the striker mechanism, but there is an ad in each
> chuck
W.T.N. advertising body parts for '29. they are the same part for '27,
'28 and '29, so you should be able to find something. Good Luck,
Geoff.
- 105 Essex Super 6
