Re: [HSS] leaking/inaccurate water temp gauge
Lew Phelps wrote:
Yes, you are right on the button there Lew, I have done this myself. >
> My '29 Town Sedan has a small but persistent water leak around the
> point where the water temperature sensor comes out of the engine block
> -- right around the "wire" of the temp, not in the threaded fitting.
> The temp gauge also reads quite low, about 130 even when the engine is
> fully warmed up.
> Can this simply be disassembled, repacked (say, with the graphite cord
> that plumbers use) and reassembled to stop the leak? How can I fix the
> inaccurate temp reading?
> Lew Phelps
> 1929 Hudson Town Sedan
use the same thin graphite string that the water pump shaft is packed
with, just a single loop should do the trick, and the same around the
collar which seals inside the fitting. Don't overtighten, just enough
to stop the leak. Good luck,
Geoff.
