Generators
For Lew's benefit, and anyone else interested, to check whether a
two-brush generator is in working order or not, short the field terminal
to ground, and connect the armature terminal to a the negative terminal
of a 6 volt battery, and the the positive to the body of the generator,
and the generator should spin slowly. If you have an ammeter, connect
this in, and it should be around 4.5 amps. If it utrns smoothly, and
does not sound grindy or rough, then you have a good generator, and if
the brushes appear unworn, just oil the front and rear bearings and you
should be in business. Remember, you will have to have positive ground
for these auto-lite generators and regulators, or you will burn out the
regulator points. All you have to do is reverse the battery and ammeter
connections. Contrary to popular belief, the starter will not turn
backwards.
Geoff.
backwards.
Geoff.
