Re: [HSS] Holley pressure regulator
Lewis Phelps wrote:
What a disgusting looking thing to have on Hudson Bulkhead!!! A vacuum>
> I installed the Holley pressure regulator tonight; it seems to do the
> job very well.
> This is a much more "precision" piece of hardware than the little
> dial-a-pound pressure regulator I had before (and which everyone seems
> to have used, because it was readily available). See the pix attached.
> A few details:
> 1. the input and output fittings screw into 3/8" IP threaded female
> openings.
> 2. There are two outputs (so it can be used in dual carb setups). One
> is plugged in this application.
> 3. Pressure is set by adjusting the 1/8" IP sized "screw" on the top.
> counter-intuitively, screwing it out DECREASES the pressure setting,
> and screwing it in increases pressure. Once the pressure is set, you
> tighten the lock nut and it will NOT change adjustment. In this
> respect, it is much peferable to the dial type units (which are not
> only inferior, but also no longer available).
> 4. It comes with a mounting bracket, so it allows mounting on the
> firewall and thus a very neat installation overall.
> 5. If the shiny chrome finish bothers you, Holley makes a satin finish
> version.
> If you're buying one of these, make sure you specify the right unit.
> Holley makes a 0-4 psi regulator, and a 4-9 psi regulator as well. For
> our Hudsons, we want the former one.
> Community email addresses:
> Shortcut URL to this page:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Part 1.2 Type: Macintosh File
> [Image]
> Part 1.3 Type: Macintosh File
> [Image]
> Part 1.4 Type: Macintosh File
> [Image]
tank would look much better, be more reliable, and eliminate any
pressure problems. Hee hee.
Geoff.
