Re: [HSS] U-Joint Seals?
Hudson29@aol.com wrote:
The dust cover has a raised edge, and originally had a cork strip>
> In a message dated 4/29/03 11:09:29 AM, hudsonut@yahoo.com writes:
> << I have a spare one for a 25 Hudson. If they are the
> same you can have it. >>
> What seals these beasts anyway? The ones on the '29 Hudson liberally coat
> the undercarriage with nice fresh grease after a lube job. At least rust
> won't be a problem!
> Fullerton, California USA
> www.aerostamp.com
inserted here. These of course soon wore away, allowing the lubricant
to spray out, as Paul has described. I have found it much better to use
a modern O-ring in here, but even then they tend to leak a bit. I also
know of others who have adapted a modern U-joint when the orignal spicer
unit has worn out, and this cures the problem once and for all.
Geoff.
