Re: [HSS] Steering box bushings for 29 Hudson?
Lewis M. Phelps wrote:
The steering box has roller cone bearings on the top and bottom of the>
> My mechanic has gone through and tightened up everything on the
> steering system, and removed a lot of the play, but not all of it.
> What's needed to finish the job is a replacement bushing (bushings?)
> for the steering box. Does anyone know of a source for these, or will
> I need to get them machined?
> The car is drivable now, but the steering begins to feel a little
> loosy-goosy at 50 mph or so. How am I ever going to win the Indy 500
> if I can't get this fixed?
> Lew Phelps
> Pasadena, CA
> 1929 Hudson Town Sedan
shaft, which is adjustable. The cross shaft has a bronze bushing, any
compentent engineering shop can replace this for you. I have found that
a little looseness in this bushing does not affect the steering ability.
The box has to be adjusted sequentially, with the drop arm disconnected
from the drag link. 1. Adjust end play of column. 2. Adjust end play of
cross shaft, 3. Adjust depth mesh of work and wheel. If all the play is
taken out, then you should have no problems. However, it could be that
your caster and toe-in is also out, which will cause the car to wander.
My offer still stands, pay my fare over and I'll do it for you free!
Geoff.
