Re: [HSS] Carb Re-Tool
jjpippers wrote:
There is an alternative, but it may not be an easily obtainable one over>
> Seems I started something here, but nevermind the electric vs vacuum
> debate for now. I have an engine (actually two) but no carbs. Is the
> consensus that I should flip the intake and go to a downdraft, or
> look for a Carter BB-1 to retro-fit?
there. The ealier Stewart carburettor used on the '23-'26 side valve
Hudsons work extremely well on the F-head motors, and being made of
brass, are virtually indestructible. Twenty years ago, on the eve of
departing for a major rally, my Marvel carb was leaking at the fuel
intake. I tightened the fitting, and cracked the casting. With only a
few hours to spare, I removed the heat exchange casting, blocked off the
exhaust manifold by-passes, made up a flange with an extension pipe
from the intake casting, and mounted a Stewart carb. The choke and
throttle fittings are almost in identical positions. I used this carby
for five years intil I eventually found a bronze Marvel carb off a
Buick, and adapted it to fit the Hudson. The Stewart performed well,
gave better fuel economy, did not leak, and was in all respects a better
unit than the Marvel, but for the sake of originality I have restored
the car to Marvel unit. The only difference between the bronze Buick
and '27 Hudson carbs is that they are single jet, and the high speed
control is on the opposite side. The single jet doesn't seem to make
any difference. I experimented with jet sizes until I found one that
gave optimum economy without compromising performance, and have made up
a link actuated from the inner side of the throttle shaft to lift the
high speed pin. I still have the Stewart as a stand-by. Watch out all
you '23-'26 Owners. If your carburettors start disappearing I will deny
any knowledge of this information.
Geoff.
