Re: [HSS] oil gauge antics
sterling40353 wrote:
Take the top off the oil pump and clean the plunger thoroughly, this>
> My '23 has an oil gauge problem. When I start the car, the gauge
> registers nothing, sometimes for several minutes. Then the
> gauge "notches" up (like the second hand on a watch). After I shut
> the engine off, the gauge continues to read (at about 4) for fifteen
> to twenty minutes. I know that I'm a little out of step with the
> world, but whats up with my gauge? Is my oil line too restricted?
> Where would it stop up?Zeke
should fix it. It is usual for the gauge to show presure for some time
after the engine has stopped. It is only an indicator that the pump
is working, not of the actual amount that is being pumped. It might pay
ti take the pump off and check the condition the of the main spring as
well, just in case it has broken a coil. Good luck,
Geoff.
