Re: [HSS] Re: Distributor weights
gene birdsall wrote:
Gene, all the distributors I have are IB 4001, so I don't know if the>
> Geoff;
> The number on the distributor of my 28 Essex is IBA4001 2H, if
> this is the same distributor as yours, I would like to have one made
> up by you so I can just install it. Please advise on how you would
> like to handle it. Thanks, Gene.
IBA is different. I suspect not, but the outside measurement of the top
removable part which houses the points is 2.91", so if you measure
across that and see. The counterweight is easily visible once you take
the top assembly off, and is a heavy die-cast weight which moves up and
down, pivoted through the centre shaft. I can send you a rebuilt
assembly and you can then send me your old one back in exchange. Let me
know, and I'll go ahead right away.
Geoff.
