oil pump and pressure
I have now surrendered the gear pump which was retrofitted to my car
and I am in the throws of making some internals for the original. I
suspect that the previous custodian changed the gauge to one that
would cope with the gear pump. It reads in PSI up to 80 lbs. This
unit is unlikley to register the performance of the original pump so
can anyone help in sourcing a servicable replacement or advise as to
what pressure the pump should deliver so I can try and recalibrate
the present one. I have a similar system on my 1913 which has a gauge
reading 1 to 4 but 1 to 4 what I do not know. I merely have messed
with the spring until it reads 2 running and all is well. The gear
pump provided so much oil that a good two pints per hour fell out of
the rear main bearing, making it a very tiresome and expensive Gordon
Bennet Centenery rally in Ireland last week.
On another note I found a 1919 engine and gearbox over there running
a saw bench and hope to complete purchase of the same later this
month.
month.
