Re: [HSS] 29 Distributor
The pressure reading is inconsequential, as it is only an indication that
the pump is working. What did it show before? How are you off for
replacement gears? I take it you mean the gear on the bottom of the drive
for the distributor shaft. How about the gear on the main timing shaft? If
you want to reduce the pressure, remove the hexagonal top cap off the oil
pump and insert a couple of fibre washers under. It would also pay to check
that the plunger valve is not sticky as well. Lew is sending me a front
transmission cap, thanks for the offer. Perhaps if yours is a spare you
could get it to Lew sometiem and that will enable him to keep a complete
transmission on hand.
Geoff.
Geoff.
----- Original Message -----
Sent: Saturday, January 03, 2004 10:05 AM
Subject: [HSS] 29 Distributor
> Thanks for the burned distributor information. There was a small crack in
the copper line at the engine end and the pump was sucking air. Replaced all
copper and oil gauge and it is showing 5, which is higher than usual.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/HudsonSuperSix16-29/
> To unsubscribe from this group, send an email to:
> HudsonSuperSix16-29-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
