Re: [HSS] 1920 engine parts
Martyn, originally the camshaft flange bore against a fibre thrust washer,
which was held in position from rotation by a peg in the cylinder block.
The peg was just a piece of bronze rod, and the thrust washer had an offset
leg with a hole which fitted over this peg. There is a spring and thrust
stud in the front of the camshaft which bears against a asurface inside the
timing cover. Unfortunately I only had two '20 camshafts, and these have
both gone already, sorry. However, I'll see if I can find another and let
you know. I can get you a crankshaft most likely, but freight would be
prohibitive from N.Z. Happy New Year, I hope you are surving the U.K.
weather.
Geoff.
weather.
Geoff.
----- Original Message -----
Sent: Monday, January 05, 2004 10:25 PM
Subject: [HSS] 1920 engine parts
> Happy New year everybody.
> I still need help for parts and some explanation to some odd ball things
> found in this engine.
> I need either a spare engine which I can overhaul or a crank which is
> serviceable. I also need a camshaft and preferably a cylinder head without
> cracks. Can anyone world wide help? I can arrange shipping from US or
> southern hemisphere.
> The oddball in the engine is to do with the cam. On the end of the gear
> appears to be a spring load which presses against the timing cover to hold
> the cam against a thrust which perhaps is part of the front bearing I
> guess. On this engine someone has fitted a ring 'thust or spacer ' made of
> exhaust gasket material not dissimilar to a creese grater which machined
> itself about a 1/4 of an inch into the bearing. The gear having run out of
> thrust has then run against the block and seems to have cut through a
> fixing of some sort at the side of the front cam bearing. Does this sound
> right to anyone? Did this fixing hold a separate thrust washer? I can take
> pictures if needed.
> Cheers
> Martyn
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/HudsonSuperSix16-29/
> To unsubscribe from this group, send an email to:
> HudsonSuperSix16-29-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
