Re: [HSS] Engine
Can you let me first find out what are common parts and also what is needed
to fit a 29H into a series 'O' chassis and fit to a 20 transmission. Many
thanks for your speedy response.
Geoff perhaps you could comment on the above? Also my cam shaft would
probably reprofile but do you have any detail of a modern profile
appropriate to that series or could you put me in touch with a reprofiler
that does?
The fibre washer that you mention is clear now and the item fitted was
obviously just a terrible choice. I can recreate such but would you think
the fibre was there to stop any noise when the gear flaoted on and off
thrust or could I fit a bronze to it. I thought of making a dolly or a
dummy cam and then fitting a tool into the flange and machining by hand the
mess on the end of the bush such as it was at least flat then sizing a
bronze thrust washer and either securing with screws or indeed a peg of
some sort. Does this sound good or would it rattle? What did the later
shafts use?
Cheers
Martyn
ps
Weather a little British but the country still on a high after Rugby World
cup in OZ
that does?
shafts use?
Cheers
Martyn
ps
cup in OZ
>I have a super six engine. probably a 29H, will not turn over. Distributor
>I took off had good gears. H. Hudson Mississippi, USA
>Community email addresses:
>Shortcut URL to this page:
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/HudsonSuperSix16-29/
>To unsubscribe from this group, send an email to:
> HudsonSuperSix16-29-unsubscribe@yahoogroups.com
>Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
>This message has been scanned for viruses and
>dangerous content by the IC-MailScanner, and is
>believed to be clean.
>see http://www.netcentral.co.uk for details
