26 Hudson Timing Chain Set-up
Greetings,
I'm trying to reassemble the front of a '26 Hudson engine. Someone
else removed the water pump for rebuild. I'm doing OK except I can't
figure out how to set the cam and crank sprockets. There are two dots
on the cam sprocket but I can find no corresponding mark on the crank
sprocket. Do I line up some mark on the flywheel with the pointer on
the bell housing or is there some other secret method?
Best regards,
David Lee
Best regards,
David Lee
