Re: [HSS] 29H Power.
Just one thing to check, that when the polarity of the battery was changed,
that the coil polarity was also swapped. If you have a modern coil, check
that the negative terminal is connected to the ignition switch, and positive
goes to the distributor. I believe the original coild were marked "SW" and
"CB", so check these and reverse them if they are still in the original
position. Otherwise, other than a good tune-up, there is not a lot you can
externally. I ahve re-profiled the camshaft on my '29 Hudson and gained
significant improvement both in power and economy.
Geoff.
Geoff.
----- Original Message -----
Sent: Wednesday, March 03, 2004 6:31 AM
Subject: [HSS] 29H Power.
> I need to increase my hill climbing power to use my 29H at a wedding
reception for
> my son. The compression is good, but I don't remember the exact numbers.
The polarity
> was changed by someone else and it has a one wire 6 volt alternator that
works well. I
> am wondering if the change in polartiy some how threw off the distributor.
I have dead
> headed the timing and it cranks and runs well until it comes to a hill.
the carb is fed by an
> electric fuel pump and I have switched out carbs to check the carb. I have
not checked
> the vacuum readings. New heavy duty battery cables from the tractor
store, I added. Any
> suggestions on increasing hill climbing power would be appreciated. I have
learned a lot
> from this group. Thanks, Harold Hudson
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
