Re castings
Sorry Brett, you
were pipped at the post. However, I can get you a pair
cast if you like. I
don't actually have the mold myself, but I knew they
were being done so i
ordered some. They are the bigger version used in the
Biddle& Smart
models, look quite good actually. .. don't worry about it
Goeff
cast if you like. I
Biddle& Smart
Goeff
Mine are fine but I
thought that I should just grab a spare pair while they're available,
...but if the cast ones
aren'texactly the same as the ones I have, I'll don't think I'll
bother.
bother.
The window winders
are around $50 each, unfinished, You can clean
them up, fit the knobs, and
get them plated yourself. Fine - I'll take two of these -
unfinished
unfinished
....Bicknell's
Hudson, which is now almost complete. well
done
done
Will post a pic of
it on the HSS page shortly. I'd appreciate you also posting
these to my own email address as I still can't open pics posted to this group
and I'd like to see them
You don't have a
spare pair of winder escutcheons I suppose? .... no Hudson
ones but I do have a couple of Essex ones which you can have if you want
(Incidentally my second Hudson was restored with all Essex hardware - and
has ever noticed that's it's not correct - even when parked beside another
Hudson)
Hudson)
Or a vent screw
shaft? -- Yes I do - complete with its
correct knob, spring and mounting bracket
Shall I post these goodies away to you - and
does a straight swap (for the 2 window winders) sound
fair?
fair?
Brett
