Extra parts
The length of copper line is probably the line from the oil pan to the oil pump. The round ball is probably the valve ball for the oil pump. The oil pump must suck oil out of the pan and not air from a leak. I can tell you from experience that the oil pump must work or the timing chain and base of the distributor will burn up. I may have an extra oil pump. Good luck,Harold Hudson
