Re: [HSS] heat riser? linkage
Darrel, lock the damper valve in the wide-open position. Normally, the
lever is facing rearwards, and is pulled forward by the linkage from the
heat exchanger. Hold it forward and wire it up in that position. Also have
the heat control set on cold, so the by-pass butterfly is closed right off.
the last thing we need in this day and age with high-volatility fuel, is
heat around the intake.
Geoff.
Geoff.
----- Original Message -----
Sent: Monday, June 28, 2004 10:02 PM
Subject: [HSS] heat riser? linkage
Does anyone have a photo or manual page that shows the linkage for
the dampers on the manifold and carb that control the exhaust for the
heat riser?
My car is missing the damper linkage and the control knobs.
Can I drive my car in a parade this weekend without this linkage?
Is there a setting that I could set it at that would be safe to leave
it at for use this weekend?
Darrel
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
List owner: HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/HudsonSuperSix16-29
Yahoo! Groups Links
