Re: [HSS] Re: Clutch lube?
The filler bung is on the front of the flywheel, and has a hollow square. A
3/8 square socket drive should fit inside to undo it. Use either a 50/50
straight 30 oil/kerosene mix, or better still auto transmission fluid.
Geoff.
Geoff.
----- Original Message -----
Sent: Thursday, July 01, 2004 6:48 AM
Subject: [HSS] Re: Clutch lube?
I have a 29 sedan.
I have looked at the flywheel, but I don't see the filler bung.
is it on the motor side or the tranny side?
is it near the center or the outside?
I was looking for a plug with a square head. is it different?
all I could find were 4 castle nuts with cotter pins on the tranny
side.
darrel
--- In HudsonSuperSix16-29@yahoogroups.com, Martyn Hudson
<hudson@u...> wrote:
> Not sure of your year but mine, 1920 is multi plate cork in 50oil/
50
> kerosine or just ATF. Just turn the fly wheel till the filler bung is
a
> third from the bottom and crack it open. I think you may find it is
dry
> good luck
> Martyn
> 10:15 30/06/04 +0000, you wrote:
> >Is there a way to check or service the oil level of the clutch
> >without removing the transmission?
> >The clutch ocassionally will remain engauged when the
pedal is
> >depressed when I first try to start it.
> >Once I rock the car a little, it frees and works ok.
> >The clutch is a little grabby, but works.
> >should I worry about it?
> >I read Lewis Phelps page on freeing up 30 year old clutch. but
this
> >seems much.
> >Darrel
> >Community email addresses:
> > Post message: HudsonSuperSix16-29@onelist.com
> > Subscribe:
HudsonSuperSix16-29-subscribe@onelist.com
> > Unsubscribe:
HudsonSuperSix16-29-unsubscribe@onelist.com
> > List owner: HudsonSuperSix16-29-owner@onelist.com
> >Shortcut URL to this page:
> > http://www.onelist.com/community/HudsonSuperSix16-29
> >Yahoo! Groups Links
> >This message has been scanned for viruses and
> >dangerous content by IC-MailScanner, and is
> >believed to be clean.
> >For queries or information please contact:-
> >Internet Central Technical Support
> > http://www.internet-central.net
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
Yahoo! Groups Links
