Re: [HSS] Exhaust nut & Heat Tube
Rick, if you can bring yourself to convert to a non-original set-up, it is
far more efficient and safe, from a gas-tight point of view, to weld a
two-bolt flange on the back of the by-pass housing, and correspondingly on
the exhaust pipe. This can be done either with MIG or arc-weld using nickle
iron electrode. Then you can just bolt it in place with a gasket.
Otherwise you will have to get a new flange ring machined, which will be an
expensive exercise. The original by-pass pipe rings had asbestos circles
specially made for this application, and the only way to seal them nowadays
is to use asbestos string (if you can find any), and pack well with exhaust
sealer paste. Or alternatively, as you don't now need any heat in this
area, with modern gasoline being as volatile as it is, block off each end
and just have the pipe in there as a dummy to look original. I'm just
giving you the easy way out, and of course if you want to keep absolutely
original, then that's your prerogative. Good luck,
Geoff.
Geoff.
----- Original Message -----
Sent: Tuesday, July 27, 2004 11:44 PM
Subject: [HSS] Exhaust nut & Heat Tube
Hi, I am replacing my cracked exhaust manifold on my 1929 Hudson
Sedan and my exhaust nut shatter while taking it off. I heated it up
red hot and allowed it to cool, then with a spanner wrench on the
nut, it broke into several pieces. It appears it is made of cast
iron. Does anybody have an extra? Is anybody making new ones?
Also, I am replacing the heat tube from the exhaust manifold to the
intake. What's up with the little thin collars to hold the pipe in
place? I had a new pipe made but the collars are a little loose on
the pipe and it will leak exhaust gas out. Does anybody know how
this was to originally seal?
Thanks for your help!
Rick Mann
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
List owner: HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/HudsonSuperSix16-29
Yahoo! Groups Links
