Re: [HSS] Valve clearence?
Inlet .006 and exhaust .008, with engine hot. You should be able to get
new packing from agricultural machinery suppliers, or pump specialists. .
Go for the graphite-impregnated type, 5 mm square section. Wrap the
packing length around the shaft and cut longitudinally to get the right
size rings. Clean all the old packing out of the gland nut first, and put
three rings of new packing in with the joints staggered , with plenty of
moly anti-sieze paste, and tighten the gland nut. you will have to
re-tightne as the packing beds in. Remember that the rear packing nut is
left hand thread, so you tighten both nuts the same way, turning the top of
the spanner away from you. Good luck,
Geoff.
Geoff.
----- Original Message -----
Sent: Thursday, September 09, 2004 11:55 AM
Subject: [HSS] Valve clearence?
What is the clearences for valve adjustment? Hot or cold? My Fire
truck is running but it leaks at the water pump. Do I need to replace
the packing? Where can I get new packing?.... Richs. Central Calif.
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
List owner: HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/HudsonSuperSix16-29
Yahoo! Groups Links
