Re: [HSS] oil gauge/oil delivery problem, late 24 Super-Six coach
Phil, you must check that you have no air leaks in the pipe from the sump,
or conversely no blockage. The pump is pretty simple, and it could be that
the pressure regulating plunger is stuck up, or the spring broken. Have you
checked that the main actuating spring is not broken? This is a special
tapered spring. Make sure the top and bottom ball check valves are in
place. Good luck,
Geoff.
place. Good luck,
Geoff.
----- Original Message -----
Sent: Thursday, November 04, 2004 7:54 AM
Subject: [HSS] oil gauge/oil delivery problem, late '24 Super-Six coach
Following purchase in 1996, I used the restored coach sparingly, but
regularly, until the fall of 2000, when I stupidly ran the main gas
tank dry, lost the vacuum, and damaged the vacuum tank in an attempt
to reestablish the vacuum. This has, after a three-year search to
find the correct vacuum tank parts, been rectified, but now I have no
indication of oil delivery from the guage when I attempt to start the
car. Back when I was regularly using the car, the guage was often
somewhat reluctant to register, but always would after two or three
brief starting attempts; now, nothing. I've tried the pump-priming
thing, with no luck. I disconnected the piping to the guage, but no
oil was present. The sump is full and I've run the car very briefly
in my feeble attempts to sort out the problem, so I'm not concerned
at this point that I've harmed the engine, but I know I can't drive
it until I know the splasher pump is doing its job. Any thoughts or
suggestions would be very much appreciated.
Best regards,
Phil Teslow
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
List owner: HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/HudsonSuperSix16-29
Yahoo! Groups Links
