Re: [HSS] Supersix flywheel, removal
Turn the engine over, and hammer on the front of the flywheel with a
soft-faced heavy hammer (copper or lead) as you turn. It will come off.
If you don't have a soft faced hammer use a block of hardwood against the
flywheel, and use a heavy steel hammer. A rubber hammer is too resilient
to do the job, it will just bounce off.
Geoff.
Geoff.
----- Original Message -----
Sent: Sunday, April 03, 2005 12:51 PM
Subject: [HSS] Supersix flywheel, removal
> Need to remove my flywheel and I am not getting anywhere. Is there a
> secret to removal as I do not want to damage the aluminum block. It's
> on as tight as can be. I removed the four nuts and washers and pulled
> out the bearing. It seems that no amount of prying is helping at all.
> Rich Smithen Thanks for any help you can offer..
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
