Re: [HSS] Projects
The interior handles are held in by a threaded collar. You need an ultra
thin spanner. Press in on the escutcheon to reveal the flats, insert the
spanner, and unscrew the collar. I have quartz-halogen on both my '28 Essex
and '29 Hudson, and have fitted a two-brush 45 amp generator to handle the
current requirement. I don;t know why you people still stick to the old
fashioned candlepower designation, when the rest of the civilised world use
wattage as the preferred and more useful definition. The q-h headlamp
bulbs are 50 watts each, which means with the draw from these plus the
ignition, tail and dash lamps you are using 109 watts, or on a 6 volt
system, 18 amps, which is just on the borderline for the original
generators. I use an Auto-Lite 4801 generator, with the appropriate
regulator. 6000 series generators are usable as well, - used on Chrysler,
Studebaker, and Hudson in the fifties. On the Essex it fits straight in to
the original holder, but on the '29 Hudson I mounted it on the left side,
and run it off the fan belt. It necessitates changing to positive ground,
but this is easily done - turn the battery around and swap the ammeter
connections.
Geoff.
connections.
Geoff.
----- Original Message -----
Sent: Wednesday, June 15, 2005 5:52 AM
Subject: [HSS] Projects
>I just got back from a long weekend of Hudson work. Now unfortunately
> I have emerged from my workshop and must go back to the weekday grind.
> I did manage to restore the horn, paint the vacuum tank and brackets
> (black!), front bumper medallion, exterior door handle inserts,
> interior window frames, upper and lower dashboards, and pinstripe all
> the interior parts (1980 BMW Brazil Metallic). I'll post some
> pictures of it sometime soon. While I was muffing with the vacuum
> tank I installed a street T fitting and reconnected the wiper motor.
> When I removed the interior window frames, I noticed that the interior
> portion of the door where the window frame sits is original paint. I
> was pleased to see that my green exterior color is pretty close.
> Also managed to set my point gap and timing (runs smoother now), and
> polish my interior hardware... all except the door handles. How in
> the world do you get them off? They don't seem to have a pin in them
> as the window rollers do, and I don't want to break anything
> attempting to learn how to remove them myself.
> Furthermore, Light bulbs. I did some experimentation. If anyone is
> looking for a brighter bulb to go in the tail or stop lamp, try a
> #1129. This is available at most auto parts stores. It will also fit
> in the interior lamp (boy, a real interior light!) Works great. If
> you want one brighter than that, go to www.MikesAfordable.com and
> order some 12 candle power bulbs (the originals are 3 CP). If you
> really want to blind someone (well, sortof), Mike's has a 50 watt
> Quartz stop light bulb and a 20 watt tail lamp bulb as well. I have
> those on order; I'd rather discharge the battery a bit when I hit the
> brake than have someone run into my car at night. All of the above
> bulbs will also fit in the cow lamps (moo) but I dont see any point in
> running any more than the 3CP #63 that came originally. They're just
> parking lights.
> On headlight bulbs, I believe all of our cars came with 21-21 CP
> bulbs. You don't want those, even if you could find them. Model A
> parts suppliers carry a 32-32 CP, or you can use a #1188 (also
> available from Mike's) which is 50 CP high and 32 CP low.
> You can also convert to quartz, but don't try it with a generator.
> Best Regards,
> James Coats
> 29 Standard Sedan
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
