water pump packings
What I plan to do is supply 6 pre-cut graphite impregnated rings of the
correct specification, plus a dollop of anti-sieze paste. Otherwise each of
you will have to buy a whole tub of this, which is completley uneconomic of
course. I'll pack the whole lot in a re-sealable plastic envelope and send
airmail. You will need to clean the shaft - easiest to rub with emery cloth
whilst the engine is running - undo the gland nuts and slide along the shaft
(caution -rear nut is l.h. thread), remove the entire old packing with a
sharp scriber or hook, insert the new packings with the ends staggered (3 in
each end), coating copiously with anti-sieze paste, and re-tighten. You
will then re-tighten as the engine warms up and the packings seat in on the
shaft. Don't over do it, you only need to tighten until the leaks stop.
Geoff.
Geoff.
----- Original Message -----
Sent: Wednesday, June 15, 2005 11:00 AM
Subject: Re: [HSS] Projects, water pump packings
> Also, thanks for the reply on the door handles. I was contemplating
> doing exactly the correct procedure. But far be it from me to do it
> without asking first, lest I ruin something.
> I didn't hear any offer on water pump packings, perhaps that went down
> before I joined the list. I'd like to buy some, I assume we're
> talking about the graphite-impregnated material installed with copius
> amounts of anti sieze that you have mentioned in the past? Oddly
> enough, and certainly contradictory to conventional thought when
> dealing with shaft-drive water pumps, my FRONT gland nut leaks. Like a
> watering can. The rear is fine.
> Best Regards,
> James Coats
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
