Re: [HSS] Engine Paint - Update & Prices
I have a really stupid question at this point - the engine
on my '30 Essex Roadster shows remnants of red paint. Is your green for these
older engines or the later ones' such as the Hornet. I would like to be as
original as possible. Soooooooo - what years - and Hudson and/or Essex is the
green appropriate for? Thanks, Alex Jones
----- Original Message -----
Sent: Wednesday, July 06, 2005 3:28
PM
PM
Subject: [HSS] Engine Paint - Update
& Prices
& Prices
After about 15 different variations of ugly green it
appears that the
Hudson engine paint is dangerously close to
perfection. I was able to
find a great paint sample today to add to
the mix under my valve
cover. The engine was painted with the valve
cover off, so the top of
the cylinder head is green. The gasket
surface is also green. This
green has been shielded from the elements
for 76 years, and has been
preserved with a light coating of oil.
Wiping off the oil reveals a
color consistent with the rest of the engine,
just in better
condition. So, I feel pretty comfortable with the
color match. It
may not match your engine exactly, because there was
significant
variation in the color that Hudson used. But, it is
darned close, and
it will be show-correct for the car.
PRICING
Aerosol Can $14.95
Pint
Can $26.00
Quart
Can $43.00
If you order a pint or
quart can, please let me know if you intend to
spray the paint, in which
case I will include a small container of
reducer. It is obviously
easiest to brush paint the engine if it is
in the car; I advise using a
foam brush to avoid brush marks. If you
like, you can then spray on a
light coating to cover up any brush
marks in the obvious, easier-to-access
areas. I am brush painting my
engine, and I have removed the valve
cover, exhaust and intake
manifolds, breather pipe, water outlet neck,
hood, radiator, and
grille shell. All of that isn't necessary, but I
wanted to paint my
radiator and firewall anyway, and replace a bunch of
gaskets, so might
as well.
To simplify things, Shipping on ALL
orders in the United States will
be $6.50, and will be USPS Priority Mail
or UPS Ground depending on
weight and address. For orders outside the
U.S., please e-mail me
your order, name, and address to JamCoats@uab.edu
and I will quote
shipping.
You can send a check or money order
to:
James Coats
6513 Quail Run Drive
Pelham, AL 35124
I will
ship your order the next day after payment is received, and the
first batch
should be ready to ship on Monday the 11th.
Best Regards,
James
Coats
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe:
HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe:
HudsonSuperSix16-29-unsubscribe@onelist.com
List owner:
HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this
page:
http://www.onelist.com/community/HudsonSuperSix16-29 0
