Re: [HSS] Spring shackles lub points?
Rich, the big problem with the oil cups is that they continue to wick the
oil out even when the car is not moving, so you in effect lubricate the
garage floor if you keep these cups filled. They changed over to grease
lubrication in 1929, and its a simple job to change all the oil cups for
modern grease nipples.
Geoff.
Geoff.
----- Original Message -----
Sent: Tuesday, July 12, 2005 2:38 PM
Subject: [HSS] Spring shackles lub points?
> My 1922 Hudson has the oil cups at the spring shackles. Can I change
> them to a zert grease fitting? Will this help or hurt the lub system?
> Has anyone else done this retro fitting? What is recommended? If I
> stay with the oil cups, then what weight of oil is recommended? and
> how much per cup?
> Thanks... Rich Smithe Central Ca.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
