Re: [HSS] 1929 Cooling system ??
I don't bother with anti-freeze myself, even though we do have frosty
weather here in winter. I run half a pint of soluble oil in the radiator
water which lubricates the pump glands and bushings. There are other
types of anti-corrosion potions which are available, and I would recommend
that you at least run this to stop rust build -up in the water jackets.
Check that it states on the label that it lubricates the water pump. Do a
reverse flush first, with the radiator hoses disconnected to preclude the
possiblility of gunge choking up the radiator core. One dis-advantage of
using anti-corrode mis or anti-freeze/anti-boil is that they will find the
smallest leak, and leave a green stain, followed by a white oxide powder.
Good luck,
Geoff.
Good luck,
Geoff.
----- Original Message -----
Sent: Wednesday, July 20, 2005 12:42 PM
Subject: [HSS] 1929 Cooling system ??
>I just drained my cooling system and I want to now if you use antifreeze in
>your system ? I have an original Bee Hive radiator with no leaks. I live in
>southern calif. so no freeze here. I plan on installing the Geoff pump
>seals and testing with water..Should I just run water, or add antifreeze ?
>Thanks Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
