Re: [HSS] Digest Number 1376
Can anyone give me spark plug numbers for the '25 and 29 Hudsons as well as make that is best suited?
> There are 10 messages in this issue.
> Topics in this digest:
> 1. Gas sending unit
> From: "standardsedan29" <sultans@webtv.net>
> 2. Tail Light ???
> 3. Re: Gas sending unit
> From: "Alex J Jones" <Thistle@fgi.net>
> 4. Tail Light ???
> 5. Re: Gas sending unit
> 6. Re: Tail Light ???
> 7. Water pump packings.
> From: "Geoff Clark" <geoffclark@xtra.co.nz>
> 8. Re: Tail Light ???
> From: "ed-moore" <ed-moore@rcn.com>
> 9. Tail-Lite
> 10. Re: Tail-Lite
> ________________________________________________________________________
> Message: 1
> Date: Sun, 24 Jul 2005 22:05:15 -0000
> Subject: Gas sending unit
> I just got my sending unit from JF Sullivan $355.20 included shipping.(6 weeks) So today I pulled my tank out and going to take it where Paul took his for cleaning and sealing. I have my sending unit out and I am going to send it to have rebuild I havent tried the new sending unit yet but I will let you know how it works. It has a different gear set then the (original?). I took a couple of pictures of them both if any of you are interested to see them I can email. The new one looks like a rebuild but looks good. I am on my way to a Hudson drive real soon..I hope.. X Fingers Ron
> Message: 2
> Date: Sun, 24 Jul 2005 22:34:27 -0000
> Subject: Tail Light ???
> I have seen 29 Hudsons with 2 tail lights. Is there someone out there that has the parts for the second tail light for sale ? Do the RHD cars have the tail light on the other side ? Thanks Ron
> Message: 3
> Date: Sun, 24 Jul 2005 17:47:20 -0500
> Subject: Re: Gas sending unit
> I just had them rebuild two of mine and received them Saturday. One has the beveled gears ('30) and the other has stamped flat gears that meet at a 90 degree angle ('31). They charged $333 for the restoration and took about 5 weeks. They look very good to me. A couple of years ago I got one of their new ones on Ebay for $95 - a real steal by comparison. They are a bit expensive but do good work. They also can restore the oil level gauge sending unit. I also had my gas tank cleaned and internally coated with an aircraft tank coating here in central Illinois - they did a very good job. They also warned that when gassing up to be very careful that the fueling nozzle does not cut into the coating as a separation may begin at that point and proceed further into the tank. One final point, check with the repair shop and find out if they also have an external glossy black paint/coating that can be applied (4 to 6 coats - each 90 degrees from the previous one) to seal it from external rust. I
> don't know yet what the stuff is but it seems like a ceramic. I will post the brand etc. if I can find out - the repair guy said he is not supposed to sell it - no label on the 3/4 pint I got. They use it on modern car gastanks that are rusty and thinning.
> ----- Original Message -----
> From: standardsedan29
> To: HudsonSuperSix16-29@yahoogroups.com
> Sent: Sunday, July 24, 2005 5:05 PM
> Subject: [HSS] Gas sending unit
> Community email addresses:
> Shortcut URL to this page:
> YAHOO! GROUPS LINKS
> a.. Visit your group "HudsonSuperSix16-29" on the web.
> b.. To unsubscribe from this group, send an email to:
> HudsonSuperSix16-29-unsubscribe@yahoogroups.com
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> [This message contained attachments]
> Message: 4
> Date: Sun, 24 Jul 2005 23:34:13 -0000
> Message: 5
> Date: Sun, 24 Jul 2005 18:42:55 -0500
> A couple of further thoughts - the reason I coated the external part of the tank was to avoid a rust through, especially where the metal support straps are. The "special" coating was used because even after I applied three coats of an etching primer plus three additional coats of a trim paint, after two weeks I had rust bleed through. I do not want to have to redo the tank again for a long time so a few extra steps now are a small investment. I also used this stuff on the external surface of the oil pan - 5 coats - after I had 23 pinholes burnt out and welded over to fill them. We then used a grinder and emery cloth to smooth the surface back to an acceptable appearance prior to coating. Apparently there are rust susceptible areas that either need replacing or extra care to preserve.
> From: Alex J Jones
> Sent: Sunday, July 24, 2005 5:47 PM
> Subject: Re: [HSS] Gas sending unit
> I don't know yet what the stuff is but it seems like a ceramic. I will post the brand etc. if I can find out - the repair guy said he is not supposed to sell it - no label on the 3/4 pint I got. They use it on modern car gastanks that are rusty and thinning.
> YAHOO! GROUPS LINKS
> Message: 6
> Date: Sun, 24 Jul 2005 19:11:11 -0500
> Subject: Re: Tail Light ???
> A previous post regarding wiring harnesses for our cars referenced a feature for twin tail lights rigged as turn signals as well:
> You can buy a complete new reproduction wiring harness with all the
> correct colors with the wires numbered, and it comes with a wiring diagram.
> The wire is fabric covered over plastic insulation instead of rubber which
> dries out. The right colors, right lengths, correct fabric covering and
> harness wrapping. It even has the metal wrapped wires where necessary as
> original. YnZ's Wiring Harnesses, 333 East Stuart Ave. Unit A, Redlands,CA
> 92374
> Phone #909-781-1498. I've used there harness on my 1929 Hudson, 1934
> Plymouth, Hudson Jet, They fit and look great. Ed Moore
> They have available the pigtails for the tail lights and I amagine they would sell them as parts instead of the whole harness assembly. I called them and went through the options available and plan on buying a complete harness w/ turn signals and ground wires to assure good connectivity as Lew Phelps and Ed-Moore suggested.
> Sent: Sunday, July 24, 2005 6:34 PM
> Subject: [HSS] Tail Light ???
> SPONSORED LINKS Hudson valley Hudson valley community college
> YAHOO! GROUPS LINKS
> Message: 7
> Date: Mon, 25 Jul 2005 17:52:35 +1200
> Subject: Water pump packings.
> By now all those who ordered water pump packings should have received them, and your Super Sixes will be resting quietly in dry beds at night! One thing I have been thinking about - why do the rear glands leak more than the front ones, and the likely reason is generator misalignment. If the two shafts are out of alignment, it will set up a vibration at the joint, which will reflect forward to the bronze bush in the pump body and of course the packing. So it would be a good idea to take off the flexible coupling, loosen the generator clamp and slide the generator forward and see how it aligns with the water pump shaft. It should be exactly in line, both horizontally and vertically. If not, loosen off the three 7/16" bolts that hold the starter / generator mounting plate, and align the two shafts. If it is out vertically, there are threaded plugs in the crankcase flange which the mounting plate sits on, and you can adjust these up and down. It would be interesting to get
> feedback on this topic. Best wishes to all,
> Geoff.
> Message: 8
> Date: Mon, 25 Jul 2005 10:27:43 -0400
> I have installed a right hand tail lite on my 29 by modifying a standard left hand unit. I photographed what I had to do to make it fit and clear the gas tank filler. I had planned to do an article about it for the WTN, but I haven't got around to it yet. Ed Moore
> From: Alex J Jones
> Sent: Sunday, July 24, 2005 8:11 PM
> Subject: Re: [HSS] Tail Light ???
> 92374
> YAHOO! GROUPS LINKS
> Message: 9
> Date: Mon, 25 Jul 2005 10:39:17 -0400
> Subject: Tail-Lite
> In my reply about the second tail-lite for a 1929 I included a photo of my 29 with two tail-lites. It is at the bottom of the message. Just scroll down. Ed Moore
> Message: 10
> Date: Mon, 25 Jul 2005 16:31:09 -0000
> Subject: Re: Tail-Lite
> --- In HudsonSuperSix16-29@yahoogroups.com, "ed-moore"<ed-moore@r...>wrote:> In my reply about the second tail-lite for a 1929 Iincluded aphoto of my 29 with two tail-lites. It is at the bottom ofthemessage. Just scroll down. Ed Moore >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hi Ed and thanks for the reply. The picture will not open on the message board. If you could email the pictures to me I sure would apreciate it. I like seeing other 1929 Hudsons. Is yours a custom or standard ? I also need to see how the top cloth and rain gutter and cloth over the sun viser is installed on a 4 door standard. sultans@webtv.net Thanks Ron
> Yahoo! Groups Links
