Re: [HSS] sparkplugs
I believe that the only spark plugs that are made now in 18 mm are Champion
D16, which are a mid heat range and 1/2" reach. The Hudson and Essex
originally had long reach plugs which went right to the bottom of the
threaded hole, but these are no longer available. So you can get any plug
you like, providing you use champion D16! However, you may just find a set
of different old stock plugs at swap meets, as I did recently. These were
KLG 3/4" reach, and were in two parts, with a threaded body, so you could
take them apart for cleaning. Probably used in the outboard motor of the
Ark! Good luck.
Geoff.
Ark! Good luck.
Geoff.
----- Original Message -----
Sent: Thursday, July 28, 2005 7:03 AM
Subject: [HSS] sparkplugs
> Looking for preferred sparkplug numbers and make for the 25 and 29
> Hudsons and if anyone knows the info for a replacement throwout
> bearing number and make for the 25, that would be
> appreciated also.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
