Vacuum Tank Plumbing
Hi Gang,
Can anyone advise me as to the correct fittings and arrangement for
the vacuum tank plumbing?
An educated guess leads me to this:
A 1/8" pipe branch tee on the vacuum fitting at the top of the
vacuum tank, with a hose barb (for wiper) on one end, and a 5/16
flare to 1/8 pipe adapter on the other (to go to the intake
manifold).
Then 5/16" OD copper tubing from there to the intake manifold, where
the line terminates in a 90 degree 5/16" flare to 1/8" pipe adapter
on top of the manifold.
The fuel outlet petcock on bottom of the tank is a compression
fitting, so I suspect 5/16" copper line to the carburetor, with a
compression sleeve and long nut at the petcock. On the carburetor
end, I am using a short piece of rubber hose and a hose barb on the
carburetor to avoid stress on the float bowl.
As for the fuel inlet, I have 5/16" copper line coming up from the
steering box area, around the outside of the firewall to the inlet
on the tank, with another 90 degree 5/16" flare to 1/8" pipe adapter
at the tank inlet.
All of the flare and compression nuts are long nuts.
I know all of this will work, but is it correct? If not, what is?
Best Regards
James Coats
manifold).
at the tank inlet.
Best Regards
James Coats
