Condenser, Starter Switch
Gang,
I am hunting a condenser for the '29. Rectangular type that looks
like a match box. Anyone have a source? I can't even find a part
number.
Also, has anyone found 5/16-24 copper terminal bolts for the starter
switch? I am sure this can be a needed item as if you are rebuilding
your starter switch they often break, or are badly corroded. I was
able to find some metric Denso starter terminal rebuild kits and make
them work, but I had to modify the terminal bolt as it wasn't fully
threaded. I believe I can make the contacts out of some copper
strip. The brass roller is a tricky part, mine isn't bad, but I feel
for someone whose is.
If I can find the parts, I'd like to put together a starter switch
rebuild kit, as many of us need to work on our switches.
Best Regards
James Coats
number.
Best Regards
James Coats
