Crankshaft, Transmission
Hi Gang,
I noticed a bottom end rattle, very minor, in my Hudson this afternoon
and immediately drove it two blocks back to my house and pulled the
oil pan off. Seems I have a loose rod bearing. Second time this has
happened in this engine, previous owner rebabbited a rod many (30)
years ago. My loose one is shimmed, so I may just be able to pull
some shims out. Otherwise, I will have to repour a rod. I need to
know first- what should the rod and main bearing clearances be, and
secondly, what are the crankshaft journal diameters exactly, for rod
and main? (I am going to check all the clearances while I am in there.
The good news is, other than a loose rod, everything else looks pristine.
Secondly- my transmission filler plug refuses to come loose, as the
square head is broken. Therefore I filled the transmission through
the shifter. Question - how much does it hold? Obviously I can't
fill it to the filler plug. I have seen a bit of discussion in the
archives about weight; the manual says a light bodied transmission
oil, so I used 85W-140. Is this kosher?
Best Regards,
James Coats
Best Regards,
James Coats
