Re: [HSS] Engine ReAssembly Questions
Answers below,
Geoff.
Geoff.
----- Original Message -----
Sent: Tuesday, August 23, 2005 7:46 AM
Subject: [HSS] Engine ReAssembly Questions
> 1. I know that head gaskets are availabe for my 1926. Are the paper
> gaskets for the oil pan etc still out there, or do I have to make them
> by hand?
***You could try Dale Cooper at www.hudsonmotorcarco.com otherwise it's no
big deal to buy a sheet of rubberised cork material and make a gasket
yourself.
> 2. What is the ropey gasket that seals the main bearings at each end?
> It sits in a groove, and I have no idea what it is or where to get it.
****Do you mean the string packing up each side of the bearing caps? Dale
Cooper has this I'm sure. There is a felt seal in the timing case, but no
seal at the rear, just a slinger and drain channel.
> 3. The crank bearings should be 0.00015 clearance, I'll set those with
> platigage. Should the connecting rods be the same clearance?
***Yes, but you have an extra zero in your clearance - pretty difficult to
measure in ten-thousands of an inch!
> Thanks in advance for any info.
> Paul H.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
