Manifold Differences
I have two exhaust manifolds here with reinforcing ribs, and on one,
the ribs continue the entire length of the manifold. On the other,
they are cut down in the center where the heat riser is. I installed
the one with the continuous ribs on my car and they interfere with the
linkage for the heat riser. The manifold that came off the car was
the one with the ground-down ribs. Were there two different designs?
Best Regards,
James Coats
Best Regards,
James Coats
