Re: [HSS] 1929 Hudson/Essex Super Six oil pump assembly
Rod, the parts are in basically in the correct order of assembly. The round
piston with the protrusion is the pressure valve. The spring goes over the
protrusion, and the top of the spring fits in the recession in the top cap.
Note that it is vitally important to have the gasket shaped as shown, with
the cut-out for the relief hole. If the hole is covered by gasket you iwll
destroy your pressure gauge. The pump would actually work without the
pressure valve, but would not register on the gauge. What happens is: the
valve closes off the delivery port. On the delivery stroke of the plunger
the oil has to build up pressure against the top spring, and this pressure
is reflected in the gauge. As the pressure overcomes the tension of the
top spring, the valve lifts, and uncovers the delivery port. Good
luck,
Geoff.
luck,
Geoff.
----- Original Message -----
Sent: Wednesday, August 31, 2005 7:51 AM
Subject: [HSS] 1929 Hudson/Essex Super Six oil pump assembly
Hello,
I am new to this group and searched around for info on how to
properly
assemble a 1929 Hudson/Essex Super Six oil pump. I have created a web
page with picture of my pump and the two items I don't know how
to
install marked with a red box.
http://home.comcast.net/~rodbengineering/oil_pump.htm
Does anyone have a picture of how to properly install the parts
enclosed in red?
Thank you very much, Rod
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
List owner: HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/HudsonSuperSix16-29
Yahoo! Groups Links
