Re: [HSS] GEOFF
Paul, glad you have finally got around to getting the car running - sorry I
ran out of time to do all the other things you wanted. And I'm slowly
getting my sight back after working on that bright red under-bonnet colour
scheme!
Geoff.
scheme!
Geoff.
----- Original Message -----
Sent: Friday, September 09, 2005 1:15 PM
Subject: [HSS] GEOFF
>I installed the carb. vacuum tank, with hose into a 2 gallon gas container
>and got the old girl running. The carb worked like you said and she
>purrrrrred like a kitten. The vacuum tank did its job like a good vacuum
>tank should. While I let it run I tried the clutch. To my amazment it fell
>right into gear..Boy was I surprised at that. No stuck clutch. I then
>hooked up my new gas sending unit (While she was running) and it worked.
>Must have a bad connection because it will only work when the engine is
>running and not with the key on..I will look into that more. When I let her
>run for a little while I shut her down. About 5 minutes later I started her
>by just pushing the starter. It never started like that before. I always
>had to choke and play with it to start her..If any of you old Hudson people
>need work on your Hudson. The cost of sending it to New Zealand is well
>worth it. Thanks for your help Geoff
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
