Re: [HSS] Oil Leak ??
It's a bit of a hassle getting the front vibration dampener off, as it will
not clear the bottom radiator mounting bracket. However, you can undo the
radiator bolts, loosen off the hose clips, (means draining the water!), and
move the whole assembly forward enough to get the dampener off. You will
have to tap it with a lead hammer or such like ot get ti come off
probably. Then you can remove the timing case and replace the seal and
gasket. Tip - if you can;t get a new felt seal, just pack in behind it with
a layer of gasket paper or soft string, which effectively shrinks it down.
good luck,
Geoff.
good luck,
Geoff.
----- Original Message -----
Sent: Tuesday, October 11, 2005 4:37 AM
Subject: [HSS] Oil Leak ??
>I have been driving my 29 Hudson around since I got her running again.(Runs
>Great). There is a prety good oil leak from the front of the engine around
>the timing cover area. I just emailed Olsons Gaskets about a timing cover
>gasket and a front seal ?? Are these replacable with out to much problem or
>is there something special I should know. Thanks Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
