Re: [HSS] Can You Identify My Block?
It is a side-valve Hudson block most likely. These were in two
configurations, first with a hole through the centre of the water jacket and
the carburettor mounted on the left hand side, then in 1923 they changed
over to a Stewart carburetoor which was mounted under an inlet manifold on
the right hand side. There are three different "F-head" blocks - the first
in early 1927 had the exhaust valves in the same position as the earlier
side-valve block. the second in late '27 and '28 models had the exhaust
valves shifted on cylinders 1,3,4,6, and then in 1929 there was an extra
hole in front and rear on the right hand side for lubrication mist to go up
to the top tappet cover. You can use a late-'27-'28 block on a '29, and
vice versa, but the early '27 won't trtanspose to any other model.
Geoff.
Geoff.
----- Original Message -----
Sent: Friday, December 23, 2005 8:17 AM
Subject: [HSS] Can You Identify My Block?
>I am trying to rebuild my 1929 Hudson engine. My block turns out to
> have three small cracks from exhaust valve to the cylinder wall.
> But, I was given a spare block with my car, which I cleaned up and
> machined flat in preparation for magn-fluxing.
> AFTER I got it all cleaned and dressed I realized that while it looks
> like my Hudson block, it has both intake and exhaust valves in the
> block.
> I am guessing it is a similar vintage Essex engine. So a) can someone
> identify it for me if I send a picture and b) does anyone need a good
> deal on whatever this is?
> In the meantine I be stripping down another engine and 'Searching for
> Mr Goodblock'.
> jj
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
