Another wacky idea....?
Since Geoff Clark refitted my '29 Town Sedan with the OEM vacuum
tank, removing an electric fuel pump, the engine has been very happy,
except for one thing.
If I leave the car parked and not running for an extended time (say,
24 hours) the carb float isn't quite strong enough to shut off the
flow of gas from the vacuum tank, and thus eventually the reservoir
in the vacuum tank will drain out, and you're out of gas, at least as
far as the engine knows.
Geoff and I installed a little shutoff valve on the line leading from
the gas tank to the carb, and that works fine -- when Cathy and I
remember to turn it off when we park the car in the garage. All too
often, we have come out to the car to find that the vacuum tank is
dry. I have become VERY adapt at refilling the tank without taking
the top off of it (details to follow, if anyone is interested).
Anyway, after this happened again yesterday, I thought that a good
solution to the problem might be to locate and install a suitable
solenoid valve (that is, a shutoff valve that would automatically
shut off when you turn off the ignition, and open to let gas flow
when you turn the ignition switch on.
It turns out that suitable valves ARE available, with 6-volt DC
coils, at a cost of about $35 each. The coil draws 16 volt-amps,
which means it draws 2.5 amps the entire time the car is running.
This might be a problem for anyone with an OEM generator and
additional electric load above and beyond the headlights, tail
lights, etc. I have converted to a higher-amperage generator (50s
era Hudson unit) so it's no problem for me.
So the question is....anyone else interested in ordering one from the
online supplier? I will aggregate orders, and then reship to each
user if you wish.
Alternatively, since this is a possibly wacky idea, maybe I should
order one valve, install it, and test drive to make sure it functions
as intended -- that is, that it actually stays in the "open" position
whenever the ignition is turned on.
Let me know what you think.
Lew
PS: if you happen to inadvertently drain your vacuum tank, I have
found that it's pretty easy to refill as follows:
1. Procure a funnel with a flexible plastic hose on the end. I use
one from Pep Boys that has a shutoff capability built into the funnel
itself, which is very nice, because you can pour a pint or so of gas
into it, position the tube, and THEN start the gas flow, at a very
controlled rate by only slightly opening the funnel valve..
2. procure an extra brass fitting, identical to the fitting that
attaches your gas feed line from the gas tank into the vacuum tank
(mine is a brass fitting for copper flare style coupling).
3. Remove the line leading from the tank where it connects to the
vacuum tank.
4. screw on the identical brass fitting, "bare,"
5. Fill the funnel with gas; presss-fit the plastic hose onto the
tapered end of the brass flare fitting, and open the valve on the
funnel. (The vacuum tank will take about a quart of gas, and it's a
good idea to pretty much fill it up with this process, to ensure that
there's enough gas to refill the carb, the line running to the carb,
and leave enough in the vacuum tank to allow it to function.)
6. Remove the extra fitting, replace the connection to the gas tank,
and start the car.
Lew
user if you wish.
Lew
vacuum tank.
and start the car.
Lew
