Re: [HSS] Re: Another wacky idea....?
In a message dated 1/17/06 11:54:27 AM, hudsonhire@hyper.net.nz writes:
the main fuel line just after the fuel tank but BEFORE the OEM
vacuum tank. (It's quite easy to bolt a plate to the bottom of the
chassis near the diff. and mount the pump on this). This pump is
wired up to a spring loaded toggle switch hidden behind the dash
board so that it will only operate when this switch is held down.
