Re: [HSS] Orbital Gears
Ken, thanks for the reminder - In the rush and confusion
of the Holidays I completely lost track. Now that saner times are back yes I
still want the steering column and hopefully steering wheel w/ levers. In the
mean time if you want to lend out the gears that's fine as I would also like to
get an extra set in the process.Sorry I dropped the ball on this and thanks
again. Alex Jones
again. Alex Jones
----- Original Message -----
Ken
Dieckmann
Ken
Dieckmann
Sent: Friday, January 20, 2006 4:26
PM
PM
Subject: [HSS] Orbital Gears
jc,
This thread has gone on so long, I forgaot the
original question....I think
you mentioned needing some of these
gears. I have an extra steering column
for my '29 Challenger.
Alex was interested in it at one time (Alex, if you
still are, let me
know) but if you need some sample gears, I can see what
condition mine are
in......
Ken In StL
>From: "John Carney"
<john@carneyconsulting.com>
>Reply-To:
HudsonSuperSix16-29@yahoogroups.com
>To:
>Subject: [HSS] Re: Another wacky
idea....?
>Date: Thu, 19 Jan 2006 15:17:52 -0000
>Hey
Ken,
>I'm referring to the gears that are attached to the bottom
of the
>steering column, that control the levers for fast idle and
spark
>advance. They are moved using levers that are on the steering
wheel.
>I think I have the right name for
them.
>jc
>--- In
HudsonSuperSix16-29@yahoogroups.com, "Ken
Dieckmann"
><kendieckmann@h...> wrote:
J,
> > This may sound beginnerish......what are the orbital
gears?
> > Ken In StL
>From: "John Carney" <john@c...>
> > >Reply-To:
> > >To:
> > >Subject: [HSS] Re:
Another wacky idea....?
> > >Date: Thu, 19 Jan 2006 03:02:31
-0000
> > >If you think about it, cranking the
engine with an open cut-off
>and
> > >no gas in the vacuum
tank isn't going to help. The vacuum
>generated
> > >by the
manifold will just pull air through the carb and into the
>vacuum tank. If you close the cut-off, The only place left to pull
> >from is the fuel tank, so fuel should be pulled into the
vacuum
> > >tank. Once there is fuel in the vacuum tank, you
should be able to
> > >open the shut-off and have it work
normal.
> > >Now, I would be happy to try and
test that theory, but I'm
> > >conveniently without a set of
orbital gears :-) (no gears, can't
> > >start the motor) So, if
anyone out there has a spare set, or is
> > >willing to loan me
theirs so I can have some new ones cast, I
>would
> > >be
forever grateful.
> > >jc
> > >--- In HudsonSuperSix16-29@yahoogroups.com, Lew
Phelps
> > ><hudsontownsedan@e...> wrote:
> > > > I have tried cranking the engine, but not with the
shutoff
>valve
> > > > (between the vacuum tank and the
carb) closed to prevent fuel
> > >flow
> > > > into
the carb. Cranking the engine with the valve open
won't
>work
> > >on
> > > > my car; it will
fire up for a second or two, but it consumes
>gas
faster than the vacuum tank pumps up from the gas tank, so it
>won't
> > > > sustain ignition. I will try your suggested
approach the next
>time
> > >I
> > > > run
the vacuum tank dry.
> > > > Thanks for
the suggestion.
> > > > Lew
> > > > On Jan 18, 2006, at 7:46 AM, John Carney
wrote:
> > > > > [snip]... couldn't
you close the cut-off on the bottom and
> > >crank
> > > the engine over a few times to get fuel back into the
tank?
>At
> > >that
> > > > > point, you
could open the cut-off and hopefully would have
>enough
> > > > > fuel to get the engine started and get
things moving again.
