Re: [HSS] Clutch Actuator
The tapered plug is simply that - a plug that you remove when you grease the
unit, not that it ever needs it, as the grease washes out with the clutch
oil that inevitably gets out past the bearing. I have never put grease in
here, as the bearing is adequately lubricated by the clutch fluid.
Geoff.
Geoff.
----- Original Message -----
Sent: Tuesday, February 28, 2006 7:57 AM
Subject: [HSS] Clutch Actuator
> I'm re-assembling my 1929 engine/tranny now. Putting the clutch
> together has left me puzzled.
> The piece I call the throw out actuator (pushed forward to release the
> clutch via the forks)has a tapered pipe plug (item 19) that looks like
> it should use the tranny keyway to prevent rotation. I know the
> actuator forks also prevent rotation, but I suspect I should have a
> 5/16" brass pin or something below the tapered plug. My plug has
> nothing under it, not does my spare tranny.
> My manual seems to show the tapered plug going right into the keyway,
> but with the pieces I have here that will never happen, I can't thread
> it in that far. Am I missing something?
> On a related topic my pistons/bores seem to be to far gone to salvage,
> I'm going to buy 3-9/16" bore Hudson 232 c.i. pistons and fit them.
> Paul H.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
