Re: [HSS] Timing Marks- 1929
Your crank gear should have two punch marks, as does the cam gear. You need
to check very closely for these and ascertain whether someone has butchered
them at some stage, or whether one of them is just filled up with gunk.
You need to set set the No.1 and 2 valves rocking, the cam gea at approx 2
o'clock and the crank at 6 o'clock, and you should have 18 pins between the
marks "As when measuring distance" as the manual says. That is, the pin
between the cam gear marks iz zero, and the one between the crank marks is
18. You then set the distributor to fire on No. 6 cylinder.
Geoff.
Geoff.
----- Original Message -----
Sent: Wednesday, March 15, 2006 2:57 AM
Subject: [HSS] Timing Marks- 1929
> My crank gear has one center punch mark, which I would expect. The
> gear for the camshaft has two marks. Is this normal? I would have
> expected one mark on each, line 'em up and you're done. One mark seems
> to be a bit deeper than the other and I wonder if someone just made a
> mistake.
> jj
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
